How can I fix the charging port?
I need help because every time I plug the charger it does not take charge what can I do to fix this problem please help.
Es esta una buena pregunta?
Check and see if the charging port looks damaged. If it does then it will probably require a new one soldering on. Unfortunately it is probably quite difficult for the average person without the correct equipment. You should be able to find someone on here can help though.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 155
