My Camera Stops Recording After Several Minutes of Video
My camera goes for about only two - three minutes before it stops recording. What could be causing this and how do I solve it?
Es esta una buena pregunta?
Check to make sure there is available space on your memory card. If your memory card is full it will prevent you from being able to record videos.
I would also check to make sure you are using a compatible SD card. All GoPro cameras require a minimum of a Class 10 SD card. Keep in mind that video files are very large, especially 4K video. A lot of memory will be required for longer videos. for more information check out the GoPro Here4 Silver's troubleshooting page.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,574
