Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Preguntas 479 Ver todo
Optical Bay SATA Hard Drive Enclosure can't be recognized?
I brought 9.5 mm SATA Optical Bay SATA Hard Drive Enclosure and equiped SSD (crucial Real SSD C300). Then I attached the enclosure unit in place of Optical drive, but MacBook can't recognize this SSD drive. I was pushing "Option" key in booting, no drive icon appeared.
Although I equiped SATA HDD (Segate 320GB HDD) to enclosure unit and attached it, MacBook can recoqnize this HDD.
I tried two SSDs, but neither can't be recognized by MacBook. I also tried to attach these SSD to 2.5 HDD connector (next to battery), then MacBook recognized this SSD.
What should I do ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
You're going to have to format the drives for use. Get a OS X Snow Leopard DVD, and boot into this. This will give you Disk Utility.
To boot this, hold C or the Option key down, and select the Snow Leopard DVD.
Once you do this, find Disk Utility. It's under Applications/Utilities. After you load it, wait for it to see the drives. In some cases, it will detect the drives need to be initalized. If it does, initialize them this way. If not, select them manually, and do it that way.
You want to use Mac OS Extended(Journaled). Don't use anything less then this.
Fue útil esta respuesta?
Calificación 3
Comentarios:
+ Good answer explaining what to do, and the steps required to do it.
por
In "disk utility", the drive which doesn't work isn't appear in the disk list when this drive is connected to the connector which was used by optical bay.
But I connect this drive to 2.5 HDD connector (next to battery), this drive appears in the disk list of "disk utility".
por
If the disk utility finds the drive in the enclosure use your install disk to format it and then try again in the optical bay.
por
I have the same problem - neither the SSD or a 7200 RPM 3.0Gbps HDD will work on the optical SATA port, but work fine on the regular slot.
Oddly Apple aren't that interested in helping :-)
Calificación 0
Comentarios:
Contact ifixt sales directly
por
Similar problem here. I can hear the hard disk spinning, but the enclosure doesn't even show up in System Profiler. Any solutions?
Calificación 0
Comentarios:
contact ifxit directly
por
Añadir tu respuesta
Hiroki Kashiwazaki estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 3,777
