Some of my clients are saying the screen keeps popping out
We don't know what we do wrong, they say it pops out a little and in some of the corners
Es esta una buena pregunta?
Probably low quality screens. Look for a supplier that sells original quality parts. iFixit has a good wholesale program for quality screens.
Fue útil esta respuesta?
How much are 5 model screens wholesale
Contact iFixit to find out, I am not a representative.
ETrade Supply figure out the iPhone 6 LCD screen assembly frame issue, which is same here, and find some details more, you can check this blog :
http://www.etradesupply.com/blog/reasons...
Better quality parts are the key to help you out. ETrade Supply also has wholesale program, visit here:
http://www.etradesupply.com/wholesales.h...
Hope it helps.
You shouldn't be using adhesive for this procedure. Those parts pretty much just pop in, and stay in. I'm guessing it's the parts your using. High quality parts are way worth it. It'll save you money on having to throw a part away, especially if you can't send it back, and save your customer from being upset. Did you take any pictures?
I didn't put I fixed a screen yesterday and they said, the screen had vertical lines, then it stopped
I've been having these problems too. I don't use original but I use AAA and usually offer 6 months warranty but recently had to reduce it to 3 because of this.
The glass is adhered via hot glue, the best way to fix this is heat up the glass (no more then 90 degrees C, going round the sides) and then push the glass back into the frame and clamp it down and leave it there until the it's dry
What screens should we buy without cutting into our profit we charge $90 for 5 models $120 for the iPhone 6 and $150 for 6 plus and also $50 for iPhone 4/4s
Check for cracks around hold button on 5c's seen several with cracks around that button which makes the phone a little more prone to popping the screen out. your only 2 choices I know of are replace back cover or a little glue around that corner of lens to keep screen from moving
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 176
1 comentario
I'm not using adhesive just pushed the screen down and install screws
- de Marques Keby
