Why is my touchscreen not working?
My screen is on but my touchscreen won't work.
Es esta una buena pregunta?
The Samsung Galaxy Tab S 10.5 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. It is commonly used for academic, recreational, and business purposes. Model number: SM-T800NZWAXAR.
Depending on the reason there are a couple of different solutions. If the screen is frozen, it will need to be rebooted. Either by holding the power button down for 10 seconds, or the power button and "volume down" button at the same time for 10 seconds. After it restarts, the touchscreen should be working. If it's still not working, the digitizer may need to be replaced. You can find the steps in more detail on the troubleshooting page
Comentarios:
touch ic replace
- de Sufiyan puthanathani
Happens on mine after blue tooth mouse has been connected. OK after reboot
- de jjdonaldson
Try rebooting or if that doesn't work a reset Hold power button and volume down button together for 10 seconds. If these did not work there is a chance you damaged the digitizer if the tablet was droped or suffered a blow of some sort.
tank you somuch i am happy
Rep: 1
Mine did this I just slapped it till the digitizer went back and it worked and still does 2 yrs later
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 120
Todo El Tiempo: 12,751
1. touch check
2. touch ic replace
