Saltar al contenido principal
Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4753 Ver todo
iPhone 6 GPS not working
Hi,
I have an iPhone 6 and suddenly the gps function stopped working.
If I turn on my TomTom gps it shows "Poor GPS Reception". Sometimes my location is found for a minute and then again it's gone. I've changed the plastic antenna on top of the iPhone without any result.
Is there anything more i can do? I'm pretty sure that it's a hardware malfunction because i did everything i could with the software.
Thx for your help
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
Hello mattis, before touting hardware try to fix by software, have you update your phone to ios9?
por
Yes, as I said in previous post, I did everything I could with the software. Restore, update, dfu, reset network settings, ...
por
See this thread for the fix!
GPS & Bluetooth work sporadically.
por
I discovered a crude solution. Ive noticed that because of wear and tear, my iPhone 6 "sandwich" is a little loose. There is some play on how the screem is attached to the body. Whenever my gps or Bluetooth is weak, i press on the screen to "compress" the phone. Boom. Gps signal restored.
por
Agregar un comentario
6 Respuestas
Solución Elegida
If you restored your network settings and checked all the hardware then you have no more options left. Mine was swapped by Apple under warranty
Fue útil esta respuesta?
Calificación 0
Respuesta Más Útil
For me - replacement of "WiFi Antenna Signal Flex Cable Ribbon " increased significantly wifi and gps sensitivity.
Calificación 1
Nobody....? Still looking for the solution
Calificación 0
I have same problem.
Message: Try to go outside but i was outside. After short time: Can not get GPS signal.
Hope somebody find this out
Arne
Calificación 0
I am having the same Issue also noticed it shows poor wifi connection even though I know it is a strong signal
Calificación 0
Comentarios:
Wifi and GPS use the same antenna, so probable there is a problem with it.
por
replace wifi antenna and cable - sure fix
por
check this part or change antenna two cable up and down
Calificación 0
Añadir tu respuesta
Mattis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 23
Últimos 30 Días: 105
Todo El Tiempo: 12,410
