El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3636 Ver todo
The bottom half of my screen is discolored and flickering.
Album: http://imgur.com/a/c66Ht
This morning, my bottom 2/3rds of my phone screen randomly started flickering, but it went away after 10-15 seconds. By afternoon, the entire half was discolored. Is this possibly a software problem?
The top corner of the panel is slowly separating from the body, if that helps: http://imgur.com/a/7iklg
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
andrienalinerush, very unlikely that this is a software issue. Looks more like either a bad LCD or a connection issue. If your Glass and LCD are separating than you definitely should consider a new display panel. It is also possible that both are coming out of the frame which may caused be a swelling battery. You do want to use these guides to open up your phone and check the LCD connections, cables and connectors carefully. Also, do not forget the battery.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
andrienalinerush estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 34
Últimos 30 Días: 149
Todo El Tiempo: 2,048
