Saltar al contenido principal
Guías y soporte para varias marcas y estilos de TV.
Preguntas 9034 Ver todo
double image one minute after starting
sony ex330 is workin well ant after 1minute the picture will become double downwords like ghos?t
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
4 comentarios
manobabu, is it a KLV-32ex330?
- de
I have the same problem and the exact same tv model!! man these things arent made to last..
- de
same problem with my tv KLV32ex330
- de
Im technisian ,,in need this fault solution
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
manobabu, sounds like a T-con board issue. Check your wiring from and to the T-con board. Also, check for obvious damage, like burned, swollen or leaking caps. In very few instances this can also be caused by a faulty power supply. Once we can determine exactly what model your TV is, we can most likely find more specific instructions.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
manobabu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,556
