Saltar al contenido principal
Tableta multimedia de 7"de Barnes & Noble, lanzada en noviembre de 2011. Las soluciones son fáciles y requieren herramientas de palanca y destornilladores simples.
Preguntas 49 Ver todo
How come my nook won't come on?
I believe my nook tablet is bricked but I've already tried several ways to unbrick the device. I've tried to download software onto a micro SD card and then put the SD card in the tablet multiple times with different suggestions that were suppose to fix it but it did not fix the device. But before I did this I tried to factory reset by holding the power button and n button down. I've even tried just to press the power button to turn it on (even though that was quite obvious) and it didn't work. I've had one problem in the past where it wouldn't go to the home screen it just loop in the first few screens when you boot it up. But the factory reset fixed it. My nook is also about 2-3 years old. So do you know how to fix it or where I could take it to get fixed, if so it would be greatly appreciated because I'm quite ready to just get a new tablet and throw this one away.
Es esta una buena pregunta?
Puntuación 3
2 comentarios
I also have a problem turning my nook off. I googled it and it says there is a button on top of nook. There are two buttons on top right and all they do is in one button increases the volumn and one button decrrases the volumn.
- de
Please tell me how to turn my Nook on and off.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Rose Lucas, first you want to make sure that you charge your Nook's battery. Leave it on the charger for a good while. After that, I'd try a complete reset by removing the Nook's battery, Then leave the battery out of the Nook for at least 10 seconds. After that replace the battery in the Nook.Restart it. Press and release the power button to restart it and allow it to fully boot before using it.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rose estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 31
Todo El Tiempo: 9,673
