A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure.
Preguntas 141 Ver todo
Why will my dryer turn on but won't start?
I can turn the power button on and the start button is blinking. It is on timed dry but the estimated time is blank (3 slashes like ---) When I press the start button it beeps once but does not start.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
My Maytag HE Sensor dryer has a light on inside, but the dryer will not turn on?
por
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Sounds like a possible door switch issue. Try opening the door and see if you get get a code on the display and a beep and the code 8:88.
Update 1/11/16
For others asking similar questions, unplug the machine for 5 minutes to allow it to reset.
Fue útil esta respuesta?
Calificación 1
When this happened to me, I checked the door mechanism first. It was not the culprit. It cost me $58 to have someone come out and tell me that the main control board was broke. The cost of this main control board is restrictive. Just went out and bought a new inexpensive replacement dryer.
Calificación 1
I had the same problem. Control panel beeps, lights go on, NO time shows and no action. This is a dryer and the only thing happening was a power outage yesterday. Everything else is fine. Clothes washer is working ok.. We tried the door switch as suggested and nothing..
Calificación 0
Comentarios:
This happened to me this morning, how did you resolve the problem?
por
Añadir tu respuesta
callie738 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 17
Últimos 7 Días: 91
Últimos 30 Días: 495
Todo El Tiempo: 9,612
