How to reset the oil change light
how do I reset the oil change warning light?
Es esta una buena pregunta?
Ivan Duben , from the service manual:"When the ignition switch is pushed to the ON position (don't start your engine), modes of the trip computer can be selected by pushing the square icon Information switch display will change as follows:
1. Current fuel consumption
2. Average fuel consumption (MPG orl (liter)/100 km) and speed (MPH or km/h)
3. Elapsed time and trip odometer (mls or km)
4. Distance to empty (dte Ð mls or km)
5. Outside air temperature (ICY Ð °C or °F)
6. Setting
ALERT
MAINTENANCE
There are 5 submenus under the maintenance menu.
BACK
Select this submenu to return to the top page of the setting mode.
ENGINE OIL
Select this submenu to set or reset the distance for changing the engine oil. Push and hold the circle icon button until the engine oil light resets on the display screen of the information center.
OIL FILTER
Select this submenu to set or reset the distance for replacing the oil filter.
TIRE
Select this submenu to set or reset the distance for replacing tires.
OTHER
Select this submenu and set or reset the distance for replacing items other than the engine oil, oil filter and tires.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 13,568
