Saltar al contenido principal
Modelo A1174 con 2 GHz Core Duo o Modelo A1207 con 2,16 o 2,33 GHz Core 2 Duo
Preguntas 212 Ver todo
How do I remove coins pushed into the optical drive?
My four- year -old has just admitted to pushing one or more coins into the optical drive of my desk top. Is it worth using a flat knife on it to ease them out or should I remove the drive and then take it apart to get at the coins? Help!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Solución Elegida
It's better to remove and open the drive. These SlimLine drives are rather fragile. Pictures of a hairclip lost in a MacBook drive here. Also the work of the owners little daughter. Where would be the Mac repair business without the little ones? ;-)
Fue útil esta respuesta?
Puntuación 3
You should be fine just using this guide to remove the optical drive, after which you can simply pick out the coins with tweezers.
Puntuación 2
Depending on how far in they are, you might be able to get them out with something hook-shaped. This might also help: Optical Drive Disc Removal Technique, or Foreign Object Removal
Puntuación 2
Añadir tu respuesta
matt846 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 5,318
