Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1238 / disco duro de 80, 120 o 160 GB / frontal de metal negro o plateado
Why do I have a gray horizontal line on my screen?
I have a gray line about one pixel thick that goes horizontally about half way across the screen of the iPod. Where should I first look in diagnosing the problem?
Update (12/14/2009)
I apologize for the terrible picture quality. The line is between "backlight" and "brightness". It isn't a crack in the screen. Thanks for the responses.
On a side note:
Any idea what causes this issue?
Es esta una buena pregunta?
Puntuación 1
4 comentarios
Can you post a picture so we can see if it looks like its damage to the actual screen or not?
- de
My ipod had multi-coloured lines across screen. Followed instructions to hold down on-/off button at same holding centre button until apple symbol appears. Did it a few times, nearly gave up but eventually the lines cleared. THANK YOU.
- de
broken inside screen
- de
just a guess but i figured it would be bigger
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Q: is the gray line there no matter what is being displayed?
I would guess it's likely a hardware failure in the LCD module, more specifically one of the outputs of the LCD row drivers, as I described in my answer to a similar question
unfortunately it's unlikely you'd be able to repair this yourself without replacing the whole LCD display module.
one thing to try - does slight pressure directly on either edge of the glass where the dead line is bring it temporarily back to life? - that might mean it's just a physical break in a connection of one output. bad news is it's likely impossible for you to resolder, the drivers are often bonded directly to the glass.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I hade the same thing on my 7th gen iPod nano. They looked like dead pixels but they weren't. Then I got these dots on my screen after a long time of using it day after day the lines went away.
- de
I have a white lines going across my iPod touch 3rd generation and when I lock my screen and my screen goes white HELP!!!
Puntuación 0
2 comentarios:
I have white lines going across my iPod touch 3rd generation and also when I lock my iPod the screen goes white ..., HELP!!!
- de
The iPod nano 3rd generation has screen problems.
- de
Añadir tu respuesta
Reese Reimers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 48
Todo El Tiempo: 27,642
