Saltar al contenido principal
Lanzada en abril de 2011, la D5100 reemplaza a la D5000 como una de las cámaras DSLR de consumo populares de Nikon. Cuenta con una lente Nikon F-mount reemplazable.
Preguntas 53 Ver todo
Want to replace my mirror
Recently I have found some scratches on my mirror. I don't know how I did this. I want to change my mirror only not the whole box. Is it possible to change only mirror glass. If possible then how much does it take to replace????
Es esta una buena pregunta?
Puntuación 0
2 comentarios
you can buy a mirror box assembly on eBay, which is what I did .
I then removed the mirror and the mask from underneath the mirror and I then replaced the two items into the camera.
- de
How did you go about removing the mirror and the mask from the box?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I have worked on a few of these cameras and getting parts is almost impossible. If you find them it will probably be on EBAY from a unit that is no longer functional. It would probably be more time effective and cheaper in the long run to just send it to Nikon for service. Taking this thing apart and getting to the mirror assembly is a 10/10 difficulty. Replacing the mirror is not for the inexperienced.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Taufiq Imtiaz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,853
