First iteration of JBL's Pulse line of wireless, bluetooth speakers released in 2013. Unique to this speaker is its light array that "pulses" in rhythm with your music.
Preguntas 13 Ver todo
JBL Pulse: Broken Charge Port Replacement
Need to access the motherboard to solder a new charge port. Don't want to break anything internally, a guide would help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 22
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Use a flat tool like an isesamo to take the side covers off. they are attached with adhesive. The side with the buttons has a small board underneath that can be taken out with the isesamo (just has adhesive) and care taking out the cable thats attached to it (standard flex cable with a small latch lock) . However there is a smaller board soldered to the main board underneath that. It has adhesive on it, so try not to lay that side down on anything because when you lift the pulse to take other screws out you may rip it off. there will be around 4 cables that sprout out each side attached to connectors. Remove the tape around it and take them out to access the two screws underneath that. There are two on the other side same position and one it the middle that needs a smaller philips. After carefully pull the pulse apart. I started from the side that doesnt have the plastic black latch. the charging port looks like its connected to a small circuit board thats connected to cables much like a dc jack in a laptop. Thats as far as I got because i couldnt get the part and dont have the right tools to un-solder and solder a new one correctly.
Fue útil esta respuesta?
Calificación 7
Comentarios:
Very well done. Much appreciated.
por
Do u have to take the end caps off? Where the speakers sit? This the pulse or pulse 2?
por
Ditto to all the above.
Calificación 0
Are you talking about the white paper like product around it under the grill and over the lighting?
Calificación 0
Añadir tu respuesta
Richard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 10
Últimos 7 Días: 44
Últimos 30 Días: 185
Todo El Tiempo: 13,608
