A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Preguntas 745 Ver todo
ps4 wont read disc, just spinning and stops SOLVED!
I have trouble with my ps4. When I insert a disc on the drive unit, it starts spinning but after a few seconds it stops. Then it starts spinning again and stops. This continiu again and again. After a few minutes, DISC IS NOT RECOGNIZED. This happends with FIFA 14 and spiderman blueray movie.
I have clear the data base, unplugged the PS4 and I am out of ideas. Any help?
Here is a link of how it sounds: https://www.youtube.com/watch?v=3_AFaJ09...
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
I'm having the exact same problems I tryed a DVD it worked then a couple of try's later a PS4 game worked check it reads DVD if so it thinks the bluray ain't an original and can't support it..I'm going to try unplugging for 24 hours then il update again...
por
I tried the method I saw on you tube but soon realized that I had a 1200 series unlike the one in the video mine had 2 screws and a different disc drive completely. Is there a way to fix the 1215A model?
por
Nvm. Fixed it like the day after I posted. Was pretty simple. Works perfect now.
por
What was your problem I'm having the same
por
I'm trying to play GTA 5 its installing only 30% then says unable to read disc . I went a month with out playing my game but it still doesn't work right now it's on 14% later on it's going to say disc not recognize happens with all my other games GTA , call of duty black ops3 , and uncharted 4
por
Mostrar 20 comentarios más
Agregar un comentario
13 Respuestas
Solución Elegida
After reading posts and saw videos on you tube I decide to open the PS4 and inspect the drive unit.
One thing that I remembered was that the last disc I insert before the PS4 dont take any more discs, was a dvd with a sticker on it. Well, when I open the drive unit SURPRISE, the label of that disc was stick on the spinning part and it blocks the laser from reading correctly the discs.
I remove the sticker, clean the glue and reassambly all the ps4 and It works.
Now I can play movies and games normally.
Thanks for your help
Best Regards.
Fue útil esta respuesta?
Calificación 6
Comentarios:
Tap the top, simple.
por
Respuesta Más Útil
FIX! I had the unrecognized disc problem for a while, tried all kinds of fixes and methods I found online and nothing worked. Until I found a fix that worked for me every single time.
As soon as I enter the disc, I start to tap semi-hard on top of the ps4 around the area where the disc is until my playstation reads the disc. Works every time. I still have unrecognized disc issues if I don't tap on it.
Please let me know if this works for you guys.
This is a repost just in case someone didn't see my answer. Some people have told me it worked for them.
Calificación 8
Comentarios:
That worked! Thank you so much!
por
Wtf bro? I tried everything but this stupid idea worked
por
Yeah, worked for my friend’s PS4 that had been doing this for years! So surprised it worked. You can hear the disc begin to spin with each tap..
por
OMG - thank you SOOO much!!! :D I was freaking out because my PS4 Pro I bought is just barely a YEAR old!! I was so worried that I was gonna have to have the HD replaced and it was gonna cost me a fortune!! Thanks so much- this fix is so EASY!
por
Reading all these comments from this post and the first answer and seeing it work for you guys is awesome. I'm glad it has helped you play your games with such a simple solution.
por
Mostrar 9 comentarios más
This is a fairly common problem with PS4's. You'll need to replace the drive or the laser at a minimum. Usually just replacing the laser will fix this issue, but sometimes they need the entire drive replaced.
I hope this helps.
Calificación 4
Comentarios:
My problem is that my PS4 won't read blu ray disks, both game disks and movies. I've tried reinstalling the current update and rebuilding the database, hasn't worked. When I insert a blu ray game or movie, PS4 rumbles and spins for a bit, then stops, then repeats several times until it says unrecognized disk. I'm left to think the laser or disc drive needs to be replaced. Any idea? Thanks
por
I have had this issue and the only thing I have been able to do is eject the disc then restart with the disc ejected. It then will start spinning and if I launch the game directly after doing this I can play the game without a hitch. However if I put it into rest mode it doesn't always come out of it. If the game gets suspended it will not always play afterwards. Say I stop to watch some netflix for a bit and come back, it just doesn't want to read anymore.
por
The lazer replaced?
No no no. this system is brand new. It has Nothing to do with the lazer.
por
David you are a saving grace sir. I feel like im back in the PS2 era trying to play GTA III smacking my ps2 to avoid the red cubes from popping up! LOL!
por
I stuck a butter knife in mine and pressed the disc down and it works now
Calificación 3
Comentarios:
Just replaced the lens in my ps4 and now it only read disc when i stand it vertical.
Calificación 2
Comentarios:
Ridiculous isn't it. Sony's reputation as a lead manufacturer of high quality electricals is being mocked by their jewel in the crown. The ps3 had issues and I had to practice all sorts of rituals to get it to work sometimes. The ps4 is 10 times worse it seems. The ps5 will probably spontaneously combust and claim the lives of children who aren't old enough to know that PlayStations have a dark side from 3upwards. I used to laugh at my friends who bought xboxs knowing full well it had the 'redring' shenanigans in store for them. At least Microsoft were open in saying their product had a limited life but was costing significantly less than the ps. What's sony's excuse? I feel like I've been &&^&@@ by them, literally sodomised
por
My ps4 regularly either won't eject discs or won't accept them. I'm quite sure its something to do with the manual eject screw. When my ps4 doesn't suck in the disc I put it in the drive then turn the manual eject screw the opposite way until it's all the way in. If the manual eject screw is a bit tight then keep on turning until you feel it go loose then tighten again then go back a slight bit to where it feels slightly loose then power on your ps4, it should start reading now, once mine didn't so what I did was carried on turning the manual eject screw the opposite way and eventually I heard a click, I stopped and powered on the ps4 and it started to read the disc again. Hope this helps!
Calificación 1
Comentarios:
Thank you! This I believe gets down to the real issue and it must be something to do with the stability of the disc in the reader when its getting read, or a slight variation of the disc ruining all readability.
por
My PS4 does a pattern of noises, then it sounds as if I placed the cd again. After doing the pattern a second time, it says 'unrecognized disc'. I tried it with several cds but it doesn't work. Please help me!
Calificación 0
Comentarios:
aye bruh me too
por
When putting disc in...tap on top ps4
por
I eject the disc and put it back in before starting the game up. It reads it first time almost always.
por
Mine was doing the same thing. I had tried almost everything, but to no avail. What worked for me was just powering the ps4 off, un pluging everything, and reconecting it with the ps4 in its vertical position. Hope this helps someone as much as it helped me.
por
i got that same problem and i got my ps4 2 year's
Calificación 0
I'm having trouble with mine at the moment and it's a new copy of fifa18 it won't read properly. Exactly what happened with fifa17 last year, coincidence or not? I exchanged fifa17 for a different copy and the 2nd worked fine, I intend to swap fifa18 for a new copy unless I can get help here.
I've initialised the system twice, once partial and the other the full reboot that takes hours, still no success and I'm not pleased truth be told. Bought it 3 years ago, not sure what model it is but it's 3 yo. I have neglected it in truth, hardly gets used and has never been cleaned properly, the vents must be full of crap, could this be a reason for the malfunction? I'm not brave enough to start taking it to pieces
Any advice on how to solve this sh*t?
Thanks, Mike
Calificación 0
Comentarios:
Yep its a common problem with PS4s.
Mine does the exact same thing, makes a ton of noise & says "Cannot start the application"
The disc will not read until i eject the disc, start application & re insert disc.
Don't listen to Playstation support, restoring your database won't do a thing.
The problem is their crappy Chinese mass production of the ps4.
por
No dust isn't the problem.
Mine is 1 year old & it's doing the same thing.
I'm betting it has something to do with anti piracy.
It's as though the Ps4 thinks an invalid disc is inserted.
por
The only solution is buy a new one.
PlayStation even stopped taking consoles for repair.
Guess they figure their customers aren't important now they're rich as Microsoft.
por
I picked up a broken PS4 a few weeks back, after fixing it I was having the same issue. Take out the disc drive, remove the metal cover and get some rubbing alcohol - clean the sliders that take the disc in but also clean the laser eye. Use Q-tips and gentle clean the laser.
This is pretty straight forward and will take you less than 1hour to do. Just ensure you have a T8 security torx screw driver on hand.
Give this a try and see, while in there blow any dust out of it.
por
No it has nothing to do with the laser. If it were the laser the thing would not read discs at all.
If you'd been paying attention you would see it does.
It's PlayStation's dodgy hardware.
We shouldn't have to pull our consoles apart, they should work we paid $500.
por
Mostrar 3 comentarios más
Had the same problem with a broken PS4 I bought and fixed. I was racking my brain trying all sorts of things to get the disc drive working, replacing flex cables, cleaning connections, etc. I finally ended up almost completely disassembling it and I found that one of the side rods that holds the laser carriage had shifted off one of the set screws, thus throwing the lens out of focus, making it unable to read the disc. I shifted the rod forward back onto the set screw and whala, it worked perfectly! I hope this helps some of you guys out!
Calificación 0
Comentarios:
What does that look like? It won’t read any of my discs.
por
but if it plays all disks except any gta disk it cant be the player and it would be too coincidental to be only gta disks that are broken mine is just telling me they are dirty or damaged but they aren't and i try a diffrent gta disk and its the same problem why only that disk
Calificación 0
I brought my PS4 about 6months ago it’s not that old, the problem is every time I insert a disc it reads it then opens the game and goes back off to tell me that the disc is damaged. I know for a fact it isn’t as I brought my gta5 game yesterday. I’m reallt not sure about what to do
Calificación 0
Okay, I don't know what's going on. I just recently got a copy of Call of Duty WW2, and I haven't been able to play it because my PS4 won't except the disk, however, if I put in a copy of a game it already knows, like Until Dawn: Rush of Blood, it works like a charm. I don't know what's going on, and I was wondering if I could get some help. Anyone?
Calificación 0
Comentarios:
Do you have space to download material to the PS4? Check and see how much free space you got man.
por
Añadir tu respuesta
Rodrigo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 425
Últimos 7 Días: 2,327
Últimos 30 Días: 11,431
Todo El Tiempo: 252,853
