How do you remove the front driver seat in Volvo 2002 s60?
how do you remove the front driver seat from 2002 S60
Es esta una buena pregunta?
Before trying to remove the seat ,disconnect the battery as there is an airbag trigger in the seat belt harness. Nothing takes the joy out of a fix faster than an airbag. remove the leg trim covers to reveal the 4 bolts necessary to remove the seat. If you have power seat you will have to disconnect the plugs for the seat controls and heater if so equipped .Two bolts can be accessed from the back One on each side and they should be mounted horizontal the two in the front go down into the floor pan once everything is disconnected the seat can be lifted out. Hope this helps
Once again be careful when working with the seat belt harness by the seat as there's a airbag trigger there
Fue útil esta respuesta?
****Before starting any work on the seat, disconnect the car battery and wait 10 minutes for all charges to dissipate *****
Though you may want to gag due to the filthy interior of the repair vehicle, the video provides clear and simple instructions to remove the driver's seat.
The YouTube repair video can be found at:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 7,149
1 comentario
is the seat power and does it have a heater
- de Jimfixer
