Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Repair guides and support for home heating, ventilation, and air conditioning system repair.
Preguntas 33 Ver todo
What does a suddenly louder AC fan (right?) mean?
It started last night: The AC is really, really loud when turned on. This happened last night. Smacking the side of the unit makes the sound normal for a few minutes.
Model: Kenmore 580.75050801
Approximate age 1-2 yrs
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Respuestas
Respuesta Más Útil
a louder fan is sometimes a sign for a loose or broken part around the electric motor
parts 8-C and 9-C would be my first guess - but there are other possible parts that could "transport" the vibration
click here for the breakdown
Fue útil esta respuesta?
Puntuación 2
Comentarios:
- Por
1) check the motor bearings. Do this buy spinning the fan blades with the DISCONNECT OFF. Is it making a noise? Does it feel like metal on metal?
You can also see if shaft seems to wobble while spinning.
If bearings are bad replace motor.
2) most likely that loud sound is your compressor. Refrigerant migrates into the oil while the system is off. When your crank case heater goes out it may sound rough for a minute while the oil heats up and the refrigerant is boiled off the crank case oil. Check this and get back to me.
Puntuación 0
Comentarios:
By* not buy. %#*@ autocorrect
- Por
Añadir tu respuesta
HealthyPizza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,985
