Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Mic and Home Button do not work after screen replacement
I changed my iPhone 5s screen and the battery. When turned on the phone and I test that the phone works right, I realized that the mic and the home button didn't work. What should i do? Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi David,
Since both the microphone and home button are not working, this would point me to believe that the charge dock connector came loose will the phone was being worked on. Microphone and home button both run through the charge dock flex. Open the phone back up and check to see if the connector directly above the battery connector is plugged in or not, try to reseat the connector. If it is plugged in correctly and is still not working, then it may need a new charge dock flex and/or a home button cable. Hope this helps.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I've tried with 3 dock flex and it do not work. That is why i don't know what's the problem
- de
i have the same problem. i tried putting the mainboard in a new phone. same problems. its something on the mainboard... i hope i get it fixed today.
Puntuación 1
1 comentario:
then , did you fix it ?
- de
The Mic & Home Button connector are both part of the dock connector flex. Trying unplugging the dock connector flex (located right above the battery connector) and plug it back it. If that doesn't fix the problem you may need a new dock connector flex cable.
Puntuación 0
1 comentario:
I've tried with 3 new dock flex and it still do not work
- de
Añadir tu respuesta
davidmavi16 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 351
