Fix or replace HE3 dryer with F70 error
We recently moved. After moving our dryer started producing the F70 error. I've opened up the top panel and bottom front panel to check all connections to ensure they are properly seated. The dryer worked fine after that for a day or 2 and then went back to the F70 error. Once again reseated the connections and it worked for another day or so. It seems like the control board is working but the connections aren't. I don't want to replace the control board if it is the lower board that needs the fix or even a cable. Also don't want to pay a repair man if he is going to just replace the main board and it might not be the correct fix. Then I'd be out $300 and still not have a working dryer. Should I order a control board and replace it, call a repair tech, or buy a new dryer?
Es esta una buena pregunta?
