Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Xbox original es el primer sistema de videojuegos de Microsoft con amplia popularidad. Posee una carcasa negra fácilmente identificable con «XBOX» grabado en la parte superior y frontal. La reparación es sencilla usando herramientas comunes.
Flashing red ring on x box original
What is wrong with it and can it be fixed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
2 comentarios
The center button on the original Xbox is blinking red and green
- de
My box has a red ring
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Craig,
Solid red, overheated.
Flashing green, bad bios load.
Flashing red-orange, bad video output
Flashing red-green, system faliure (can be alot of things)
An indicator light that is flashing red indicates that there is an Electrically Erasable Programmable Read Only Memory (EEPROM) error and that Xbox cannot start.
EEPROM is a memory device that does not lose the information programmed to it when power is lost. This is where items such as language setting, video modes, audio modes, and game region are stored.
THINGS TO TRY
1. Remove all discs from the Xbox console.
2. Turn off the Xbox console and leave it off for thirty seconds.
3. Carefully read the Xbox instructional manual that came with the Xbox video game system for instructions about to use and how to position the Xbox console to avoid overheating and other problems.
a. Make sure the Xbox console is not located near a heat source. Heat sources can include TVs, computers, monitors, and other electrical devices.
b. Make sure the vents are not blocked. There are vents on the left and right side, and on the rear of the Xbox console. Make sure each vent has at least six inches of clearance and space for air to circulate. If the Xbox is inside a cabinet, move it to see if this prevents heat problems.
4. After the Xbox console is set, turn it back on and make sure that you see a steady green indicator light on the front.
from here.
If none of that works, you do want to disassemble it, using these guides and check your fan. Let us know what works.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
I'm wondering if it does get the red ring and you have to fix it, wht about the hard drive? Are my pre-existing saved games still gonna be there?
- de
Check to make sure your display cable is connected. Mine flashes red when it is not.
Puntuación 1
For me this can happen when the Composite/Component plug isn’t inserted all the way in the back slot
Puntuación 0
Añadir tu respuesta
Craig estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 133
Todo El Tiempo: 45,138
