has a code cl this washer has no pin to replace
washer has an error code cl but has no exterior pin to replace or to activate door latch
Es esta una buena pregunta?
jjschnaib, this error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
Fue útil esta respuesta?
pushed and held all buttons for 5 sec and that worked
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 91
1 comentario
Your question is a bit confusing. Can you pleases clarify what you mean by "no exterior pin to replace or to activate door latch"
- de oldturkey03
