Should the shield of the A7 CPU be removed to?
Hello Jessa, i have an water damaged 5S logic board. Should the shield of the A7 CPU be removed to? I've heard that that cpu is using les then 1,5 volt + the water dind't came there. Thanks anyways!
And how do i remove those shields without an hot air station or an hot air gun?
I got some heat resistance aluminum tape and a torch lighter. Can i remove it with this if i do it carefully and if i mask the connectors and expossed parts of with some aluminum tape?
Es esta una buena pregunta?
