iPad mini repair: home button activating on its own?
So I just repaired an iPad mini and when I closed down the new screen the home button started activating on its own. Its stuck? Help!!!
Es esta una buena pregunta?
Usually this means the ribbon cable didnt have tape over it to protect from shorts or you pinched the cable and caused a short in it.
Fue útil esta respuesta?
I removed some yellow tape from over the home button on the new screen...should I put it back on?
yes also make sure you have no creases in the ribbon cable. It should be folded but not hard bends.
dude thanks so much! I was freaking out, never ran into that issue before...and fixing iPads is extremely stressful. You are a life saver
No problem. Ive been there. Its very frustrating.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 95
