Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0.
Preguntas 490 Ver todo
Charging in very long hours and battery exhausts very soon
Hi,
I have Samsung Galaxy Tab 3, Model SM-T211 with Android version 4.4.2, Kernel Version 3.4.5-4496770.
I had issue with my tab was it used to take long hours to get battery charged and used to exhaust the battery within 2-3 hours. It used to turn off when the battery was 40-50% or sometimes at 60% too. I have changed the battery but it still is taking very long hours to get battery charged full. Last time I started charging at 1600hrs and it charged completely at 0900hrs in the next morning (about 25 hours). Please help me to resolve this problem.
Ashwani
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
2 Respuestas
Solución Elegida
Either the battery is not charged with a powerful charger, so it will take long to charge.
Or the device constantly runs with high CPU load, then you should use a CPU monitor App to verify that first.
Last possibility is a old or damaged battery, which then needs replacement.
I had this problem on my Galaxy tab 2 also, because a Program was constantly using up the CPU.
Fue útil esta respuesta?
Puntuación 1
Thanks a lot for your quick and very helpful response. Can you please help a bit more by adding how to manage CPU load and how to verify the App.
Puntuación 0
Comentarios:
There are several Apps to check the CPU load for Android in the PlayStore.
For example https://play.google.com/store/apps/detai...
This will show you any process that is constantly using up too much CPU (if that is the case for you)
- Por
Añadir tu respuesta
ASHWANI estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 828
