Saltar al contenido principal
2.26 or 2.4 GHz / White plastic unibody enclosure
Preguntas 691 Ver todo
Wifi: No Hardware Installed after reassembling (N camera, Y Bluetooth)
Okay, so I spilled milk on my computer (It happens), and I disassembled it and cleaned it and let it dry out. I put it back together and it worked! . . .mostly.
The Wi-fi says "No Hardware Installed", but I did not leave out the wi-fi card or any other part (except 3 tiny screws).
My camera doesn't work (the light won't even turn on), but Bluetooth works very well.
What gives?
SMC reset?
PRAM reset?
Apple store visit?
Something else?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Once you took the board out did you clean it with isopropyl alcohol. Is there any corrosion around the Wifi, Bluetooth and camera connector?? If so clean it all carefully with toothbrush and alcohol.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Scott Olling estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 82
