Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4256 Ver todo
How can I fix a loose screen?
When I touch my screen it moves ever so slightly up and down. Is there a way I can replace the rubber seal between the iPhone glass and the metal housing to make it fit more snug? If this is possible, where can I find the parts? Thanks!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
6 Respuestas
Solución Elegida
Sounds like a refurb defect. If it is a brand new phone--return it! Cheaper aftermarket iPhone 6 screens have a 'lift' between the screen glass and the plastic bezel. A quality iPhone 6 screen that is properly installed will not have a lift. Correcting a lift on a cheap screen is a pain.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Funny I'm having the same problem and I got the screen from this website and its apparently OEM.
por
Hi,
Firstly, it's not a rubber seal, its plastic.
Secondly, your best bet is try and glue it down, as it appears that these iPhone 6 replacement screens always peel away from the frame.
Calificación 2
Comentarios:
Firstly, it's a brand new phone.
Secondly, don't care what it's made of.
por
He was only trying to help...
por
Thanks David, some people don't like help these days...
Wow bub, don't come on ifixit if you don't want answers, you should drop the attitude. If you went to anywhere with that attitude for help they would of told you to gtfo.
If it's a brand new phone, common sense should've told you to take it to apple.
por
Plus, you never mentioned it was a new phone in your question, so everyone would have assumed you've had the screen replaced by a third party screen.
por
If its a brand new phone take it back
por
Mostrar 2 comentarios más
The glass is adhered to the plastic frame by hot glue.
The screen gets hot the glue gets soft.
I've seen this multiple times on GENUINE iPhone 6, it looks like it's becoming a common fault.
Calificación 0
I use a 2 component expoxy glue and a injection needle to apply the mixture very precise.
Apply the glue on the frame and place the frame on the glass, apply pressure for 2/3 hours and it wont come off ever again.
Calificación 0
Comentarios:
Does that really work? :'( the problem is happening on my lg g3 too :'(
por
what kind of epoxy and injector do you use?
por
And will it come off again when I NEED it to?!
por
I have the same problem. It's most likely if you relize when you charge your phone and the battery becomes very overheated, the battery is faulty. This is not normal. Sometimes the battery will overheat but not to an extreme extent. Just take it back to Apple and they will give you a new one free of cost. I got a new one too. But this may be a bit too complicated to fix at home. Guess that upgrade will have to wait. :)
Calificación 0
On my iPhone 6s, the top of the screen popped off when I dropped it, I turned it into at&t and they fixed it for 100& but I dropped it again and it broke again, I cried. My mom is done paying for my phone. Do ou know what I could do
Calificación 0
Añadir tu respuesta
Bub estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 37
Últimos 7 Días: 211
Últimos 30 Días: 992
Todo El Tiempo: 55,471
