Why does my beats pill only work when it's plugged up
My beats pill only works when it's plugged in once I take it off the charger it doesn't work no matter how long its been charging
Es esta una buena pregunta?
Shakim Prince, double check to make sure that yuor charger works and that your cable connector as well as the charging port are without any damage. Check for bend, missing or corroded pins. If you find all that in good order, it is entirely possible that your battery is no longer holding a charge. Use this guide to replace the battery.
Fue útil esta respuesta?
Good day, I have a Beats Pill + and it won't turn on unless being plugged in also only the auxiliary works. I've checked the batteries which have charged 100% so I don't understand what the problem may be. The only thing that makes sense is the possibility the connection from batteries to main pcb is bad which would explain why it will only works while being plugged in with batteries 100% charged. While being plugged in you can see the Beats Pill + is changing normally. There is one other possible problem. Maybe the battery protection pcb has a issue? Is it possible that the battery protection pcb only allows incoming power, but not outgoing power. Thank you to whoever reads this message and attempts to figure it out or knows something that is a typical problem with the Beats Pill Plus Bluetooth Speaker System. Thank you very much for your time.
Respectfully, Kevin
Is your battery showing 127%?
I have this problem 127%
I have this problem, how do I fix
same problem here
My battery is showing 127% and it won't work without charger. How can I fix it?
no one has answers, same here 127%, fmk!!! i CAN'T FIND A REPLACEMENT BATTERY ANYWHERE
It is because if you play music or audio while you have it plugged in it will ruin the battery. If you want to fix it what you need to do is take it apart and buy a new battery, but I will warn you that the battery is hard to get to, and you have to carefully move everything inside in order to get to the battery. You also have to be carful of the speakers because they are magnetic and as you remove the tiny screws connected to the battery they will hit it and it can break the speaker. Depending on what type you have will depend on what new battery you get. You can also try to reset the battery to see if that works. I will warn you that most of the batteries I have seen online are expensive. Well, I hope you can get it fixed.
You need to get a battery replacement had the same problem with mine just replace the battery
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 113
Todo El Tiempo: 44,807
1 comentario
If the motherboard has a little corrosion do I need to replace it?
- de Amanda Lee Alvarez Casias
