My iPhone is not charging
my iphone is not charging. i replaced my charger and charging connector dock. but wont charging.it nothing shows.its not charging can any one please help me
Es esta una buena pregunta?
knaveenkumar12345, time to open up your phone and take a look at the logic board. Check the components around the battery connector and make sure that the connector is properly installed. If your battery comes on with a fresh battery but does not charge, it is possible that you have a bad power management IC. That is a BGA IC and needs special tools and skills to replace. It is also possible that you have a failed charging coil or "USB fuses". You will at least need a multimeter to check those components for continuity.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 99
1 comentario
Just to make sure, you also replaced the charging cable?
- de oldturkey03
