Dual hard drive data doubler
Hello,
I have a Mac Mini i5 late 2012. I bought from OWC their drive doubler.
I have a question when I disassembled the mini once the drive doubler arrived to remove the original hard disk (500 GB). I could not and realized that the HDD is already using the SATA Port. Instead I need fasten to the the SSD port, suddenly rubber pellets do not serve me.
If I place the SSD instead of HDD how then install the HDD? The SATA connectors are identical! I do not understand!?
Thank you
Update
Yes thank you a lot !
I managed it was just that I put over my HD SSD upside and perfect.
Just I do install again Yosémite because don't work perfectly the SSD place in the mini 2012 i5 comes from mini 2009 core2duo.
And the HD in the mini 2009 come from mini 2012.
In the 2009 I do command option P+R to start because don't start.
I make an usb key with Dismaker for make a clean install
Es esta una buena pregunta?
