Saltar al contenido principal
Procesador Intel de doble núcleo modelo A1502 / 2.4, 2.6 o 2.8 GHz / Lanzado en octubre de 2013
Preguntas 551 Ver todo
Can replace for mbp retina 15"early 2013
i have a early 2013 mbp retina 15", track pad done work, can i replace it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
I noticed you mentioned the 15" model but tagged the 13 inch. Assuming that you have the 15 inch model, here is the disassembly guide, and you can stop when you get to step 38. Here is the trackpad replacement guide (meant for the 13 inch, but it still applies). You can order the part here. Before you purchase the part, check to make sure the trackpad ZIF cable is properly seated on the logic board and is not loose, since that could also be causing your problem. These cables are sensitive and can become dislodged.
Imagen de MacBook Pro 15" Retina Display Late 2013 Upper Case Assembly
Guía
MacBook Pro 15" Retina Display Late 2013 Upper Case Assembly Replacement
Dificultad:
Difícil
2 - 4 hours
Imagen de MacBook Pro 13" Retina Display Late 2013 Panel Táctil
Guía
Reemplazo del panel táctil del MacBook Pro 13" Pantalla de Retina finales de 2013
Dificultad:
Difícil
1 - 4 hours
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
hi Robert, thanks for answering, i got another problem, all the trackpads i find online are for late 2013 and this one is early 2013, i dont have the mac to check im buying it and thats the issue with that mac, he says it just stopped working. it might be what you say. Coming back to my comment, is there a different trackpad for mbp 15"retina early2013 ?
- de
This appears to be the one for that model. When the laptop comes in we can troubleshoot the issue further.
- de
Añadir tu respuesta
crixelf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 530
