Saltar al contenido principal
Cámara de acción HD con pantalla táctil LCD, lanzada el 5 de octubre de 2014.
Preguntas 87 Ver todo
I dropped my gopro hero4 onto a hard floor.
I dropped my gopro 4, now it will not turn on or charge. Once I picked up the unit after dropping it, the rear lcd screen was kind of glitched out also. It wouldn't turn off(the screen) so I took the battery out, ever since, it's been dead.
Anyone got any ideas as to what might've bunged out in this thing, what might need replacing or any other ideas?
Cheers.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I'm not sure about the Hero4. Is there anyway to reset it? If yes, this should be tried first.
If there isn't a way to reset it, or reseting did not solve your issue, then can you place a known good charged battery inside your GoPro and see if it works.
- If the GoPro works with a charged battery BUT does not charge, then either the charging port or the charging circuit on the board are damaged.
The charging port is a pretty straightforward repair that nonetheless requires a professional with the right tolls and skills.
The charging circuit, now that's a different story.. special skills and tools are needed also, and the right type of experience in trouble shooting fixing those things.
- If your GoPro does not run on a charged battery, then something in the board's circuit has been damaged.
Repairing a faulty board that doesn't start is not straightforward; and finding and fixing the issue will rely on the skills of the repair tech and the extent of the damage.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
krismoit estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 1,846
