The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0.
Preguntas 458 Ver todo
I need help to repair the charging port
but the problem is the board damaged when the charging port brooked as the attached photo https://www.facebook.com/photo.php?fbid=...
the lead welding doesn't stick to the board
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
mohtraxx, looks like you are not using enough flux, and an iron that is to big. If not sure how to properly attach it, I'd suggest you send it somewhere to get it soldered before you lose the solder pads as well.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Thank you oldturkey03
The problem is whil I removed the old port the bins removed with copper pads on board
por
the outside pins came off with the pads? Post an image of your connector as well with your question
por
Mostrar 2 comentarios más
Añadir tu respuesta
mohtraxx estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 144
