How to replace the battery?
In MBP mid 2014 (MGXA2) battery is glued to the bottom of the case. Can i replace the battery on my own? Do i need any special screwdrivers?
Es esta una buena pregunta?
You'll have unstick.
I do not recommend using hot air.
Use spudger um below the battery com care, and lift slowly.
It seems that there are no screws on the battery.
Fue útil esta respuesta?
Thanks, what glue i can use to stick my NEW battery back on the bottom of the case?
Pero no compres de 2mm, compra uno de 5mm o 10mm ;-)
Normally, the new battery should have a new adhesive.
If not, you have to use a new adhesive, like this:
[producto vinculado inexistente o deshabilitado: IF145-283-1]
But do not buy 2mm, buy one 5mm or 10mm;-)
Look at this guide, it is the macbook pro "13"
The process you have to do to remove the battery is equal to this.
In the Macbook pro 15 you indicated us, does not have screw
Reemplazo de la batería de MacBook Pro 13" con Pantalla de Retina Mediados de 2014
Good work!
Here is a battery, comes with adhesive ;-)
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 328
