Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3883 Ver todo
Battery capacity not consistent with endurance
My iPhone 5s is a year and five months today. The battery capacity reads 1400, and at design it was 1550. I believe that should mean it still has quite some life left in it, but alas it does not last three hours with my normal usage which mainly consists of chatting.
Is it time to replace the battery or do I have a possible underlying problem I need to rectify first?
Resetting settings did not help at all. When fully charged and just in standby, it would lose one percent every hour or two, depending on the ambient temperature. Soon as I pick it up and start using it, I lose 10% in 5 minutes. This one time I charged fully before going to bed; woke up to a dead phone. This other time, it lost 50% overnight without being used.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Update:
After taking a friend's advice I charged the phone with a 2.1A charger from 20%. This was supposed to resuscitate dormant cells or something along that line. It remained at 100% for a bit, but then started dropping like it had a leak. I left the phone alone when it was at 85%. Five hours later I picked it up, it was still around 80%. Started responding to messages and calls I had missed. It dropped to 29% within the hour. That was it for me. I was gonna put on my space suit and swap the battery.
Before [image|581707]
After swapping the battery, the charger seemed to be charging it too fast so I hooked it up to my computer instead. It still seems to be charging at the same speed so I can only wait to see how it fares with my normal usage.
After [image|581708]
por
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The iPhone 5 had this issue due to the U2 chip on the logic board failing. I don't know if this issue exists with the 5S, but a battery replacement would be the best first step in determining whether the issue is the battery or something deeper. Do you have Applecare or any warranty on your device? If so, I would recommend you use it and ask for a replacement device. If not, you will want to order the battery replacement here and use this repair guide. If you do not have the tools required for the repair, I recommend you order the kit version.
Imagen iPhone 5s Replacement Battery
Producto
$29.99
Fue útil esta respuesta?
Calificación 2
Comentarios:
I already bought the repair kit. I just want to be sure I won't be swapping a good battery for a new one only to notice poor endurance again.
por
Añadir tu respuesta
babachibado estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 71
