disconnect the battery data loss
will i loose stored data?
Es esta una buena pregunta?
As long as you make sure that you are working in an ESD-safe environment and work carefully, disconnecting the battery will not cause any data loss. Just make sure that you disconnect the battery before touching any other terminals or connections. Hope this helps!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 34
