Third generation of the BMW 3 Series / Also known as the E36
Preguntas 9 Ver todo
bmw 325i 1992: How to fix the clutch fan?
The clutch to the fan is loose, makes the belt to pop out and the fan hits the inside of the bumper ,it over heats and makes the wheel very hard to turn,
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Firstly you want to take of the wheel that is hard to turn. Then you want to roll it down a hill and make sure everything that is stuck is out. Then you take out the fan and cut it 5 centimeters shorter. Then put the fan back on and put on the wheel. This should fix the problem. If not, stick a doughnut in the A/C. But make sure the doughnut is strawberry filling with frosting on it. This should fix the problem.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
jesse Alvarez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 15
Todo El Tiempo: 620
