Saltar al contenido principal
Guías de reparación e información para la línea de tabletas 2 en 1 Surface Pro de Microsoft.
Surface Pro won't turn on but the home button still works.
My surface won't turn on.
What happens:
1.the charger's light is off
2.the screen is off
3.the home button vibrates when pressed
It isn't in warranty anymore but I can't afford to replace it and I do not have the right tools to fix it...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
4 Respuestas
Respuesta Más Útil
it might be stuck in standby mode or the screen might be bad. Try a full reset by holding the power button and the volume up for about 15 seconds and see if it will reset to the surface logo- if it does it should boot from there. This might be one of those surface stuck in standby glitches that can be fixed by a full power off with the above step.
Fue útil esta respuesta?
Puntuación 2
I’m having The same problem please help
Puntuación 1
1 comentario:
Yes, me as well.
- de
Tried the hard reboot with the volume up, and power button, but it did nothing. Are there any other ideas on how to fix this ?
Puntuación 0
I have had the same issue for 2 years with my Surface 2 purchased in 2013.
Symptoms:
  • when I press the power button, the screen does not start (stays black)
  • the windows button works (ie it vibrates when pressed)
  • the power cable’s light is on for approx. 10 min and then goes off
  • When I hard reboot, the windows button does not vibrate anymore
I managed to start it again by hard rebooting then pressing the power button many many times. At some point, it starts, and when it does, I keep it turned ON all the time (no sleep, no hibernate, no power off - see power options).
I don’t know how to fix it. I feel it is the battery because the time goes off after such restart. Battery should keep it but it does not, so that’s my clue.
Please help. Thanks in advance!
Puntuación 0
Añadir tu respuesta
elamzachariah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 4,355
