Saltar al contenido principal
Potente pero sorprendentemente compacto, este sistema de planchado produce vapor a alta presión sin parar.
Why my steam iron can't get steam come out
The steam iron, I get the problem is steam don't came out...when I press the pressure button on the handle ,steam don't came out n the water still get boilling no steam out. How can I fix it?
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
3 Respuestas
Solución Elegida
Hello,
I would try using a 50/50 mixture of distilled water and vinegar. I use this mixture to clean my coffee pot and steam mop. 90% of the time it works everytime!
Fue útil esta respuesta?
Puntuación 3
Hello!
I just find some good web page. This problem is related to electronic, pump power supply.
https://lieven.kks36.be/2016/06/11/phili...
I hope it will help You.
Best regards!
Marin
Puntuación 0
2 comentarios:
How can I solve my steam generator problems, it do trip off if you pressed pressure bottom on the handle and steam doesn't come even after I cleaned it with 50/50 with white vinegar. Bello
- de
Brilliant thank you. It's working now. 😁👏
- de
Try opening cap where the water is topped up. If it starts to steam then, on my Philips Azur, there are two tiny pinholes in the cap which were blocked. A poke with a pin was enough to sort the problem. They allow air to enter as it steams, otherwise a vacum would occur and stop the water flowing.
Puntuación 0
Añadir tu respuesta
phongtu008 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 26
Ultimos 30 días: 102
Todo El Tiempo: 70,291
