Saltar al contenido principal
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Preguntas 492 Ver todo
iMac 2008 Shut Down Unexpectedly and Won't Come Back On
So last night I had just downloaded Final Cut Pro with no problems and had then downloaded some video clips to play about with in the app. When I tried to open the app, however, i had a message saying there wasn't enough space on my iMac. Everything still seemed fine, but then a few moments later my iMac shut down unexpectedly and so I turned it off in the plug and left it overnight. When I tried it again this morning it wouldn't come on. I have checked the power cable and have tried two other power cables but it still won't come on. I've tried the method where you hold down the button for 10 seconds whilst unplugged too.
Does anyone have any solutions, please?!
P.S is there any point taking it to an Apple store seeing as it's an old model and I bought it second hand? Plus my nearest Apple store is very, very far away and so I can't travel there.
Thank you in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Can you give us the last four digits of the serial number so we can correctly identify your system. You'll find it on the bottom of the stand foot (use care when you put the system on its back to access it).
por
Also have you tried disconnecting the power cord for a good 10 minutes to see if that works. Also make sure the power strip outlet you plugged the system into is working.
por
Yes, the llast four digits are 3ZE4. Yes I have tried disconnectin thr plug for a few hours, but still not working and have tried it in different sockets too.
por
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Respuesta Más Útil
Are you up to fixing the system your self? If you're game follow this IFIXIT guide to access the diagnostic LED's: Technique: iMac Intel 24" EMC 2134 and 2211 Diagnostic LED's. Let us know what they tell you.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Emily estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 159
