Replace HDD with SSD
I understood that iMac 21" basically has two slots for drives: One of which is located on the main board for "Blade" SSDs provided by Apple. As those are quite expensive and it seems not so easy to unmount the logic board I thought of replacing the HDD (2.5" SATA I guess) with an SSD.
Are there any models you can recommend? I read about difficulties with the temperature sensor which only works with certain SSDs.
I work with final cut an store my footage on Thunderbolt-Drives anyway, but still it boots quite slowly due to the HDD and I want to speed it up a little.
Thanks for your answers.
Es esta una buena pregunta?
2 comentarios
Which configuration did you get? HD & SSD if you got one with it.
- de Dan
Right now it has no SSD or fusion drive. Just HDD.
- de svenstoermann
