Back housing iPhone 5, 5c, and 5s interchangeable?
IPhone 5 interchangeable housings.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
6 Respuestas
Respuesta Más Útil
no, they are all different.
Fue útil esta respuesta?
Calificación 2
I put my 5s in a 5c housing everything fit perfect, But the iPhone 5 is layed out different from both.
Calificación 1
Comentarios:
How did you do that..? How did the 5s flash fit into the 5c housing..?!
por
Believe it or not the housings for both these devices are laid out the exact same when it comes to screw positions. Then you swap out the headphone/lightning port cable as well, and the camera sensor, and the get a custom plastic frame for the display assembly to put on a 5S screen and it should work! The frame for these devices is exactly the same when it comes to screw lay out too... It's weird how some of these parts were designed the same. Even the battery is backwards compatible. I want to do it myself and have a 5CS... LMFAO It'll be an iPhone 5C in the S housing...
por
So can I just buy a 5s housing and put my 5c into the 5s housing
por
You can, but you will also need to buy the plastic frame that surrounds the display and helps it clip into place. I'm not so sure how the flash module would work since the 5S uses Ture-tone, and the 5C has a regular flash. But be sure to swap out the lightning/headphone port as well since that's what connects Touch ID to the 5S and it has the home button prongs on the 5C
por
ipodnanofreak420 where can someone buy this custom plastic frame?
por
nope, but while i am on, if you want your iPhone to look like an iPhone SE model then just buy the iPhone 6 mini housing from ebay for whatever variant you have 5C/5S/5. i changed an iPhone 5 to the pink colour SE and it looked very well
Calificación 0
Comentarios:
can you provide a link?
por
Dude, can I change my iPhone 5c full body as like iPhone 5s or se??
por
Dude how can you say an iPhone 5s housing won't work but in iPhone se will! They are practically the same housing lol
Calificación 0
Can I change my iPhone 5c panel as iPhone 5s or se Pannell??
Calificación 0
Anyone know where to find the custom plastic piece that ipodnanofreak420 mentioned which adapts an SE screen to a 5c housing?
Calificación 0
Añadir tu respuesta
Trevor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 38
Últimos 30 Días: 179
Todo El Tiempo: 8,957
