Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
Lines across bottom of screen
I have 2-3 thin lines across the bottom of my 1st generation iPhone. It does not prevent me from moving the lock screen button and getting on to the main screen, but I would like the phone to be in perfect condition. Can you tell me what part needs to be replaced and how difficult a job it is to do??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Here is a list of steps you can try!
  • Software issues
    1. Restore (Google it) Back up first!
Or
  • Hardware Problems
    1. Bad Screen (Change It!)
    2. Bad Logic Board (Change it too! HARD and Back Up first!)
Hope I helped!
Fue útil esta respuesta?
Puntuación 1
Original iPhone front screen replacement is among the most difficult iPhone repairs there is. Watch a few youtube videos to see the process. Unless you have extreme skill, you will not even be able to open this iPhone without permanent damage to the iPhone case. In the future, if the battery eventually fails, battery replacement is much easier, but again, a very difficult process. The Original iPhone is not a repair friendly iPhone.
Puntuación 0
I assume it is CHEAPER if you buy a used NEWER iPhone for less than 100 € than trying to replace the display !
I have the same problem since several years, and have upgraded first to 3g and now a 4s model in the meantime
Puntuación 0
Añadir tu respuesta
pbassey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 570
