2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Preguntas 312 Ver todo
Swap top case(display) from retina 15 2012 to retina 15 late 2013?
Does anybody know if it's possible to use the top case with display from a mid 2012 macbook pro 15inch retina on a late 2013 macbook pro 15 retina?
From what i can tell the main difference is that the 2012 has a "n"airport card and the late 2013 has "ac"airport card.
Are the antennas different?
That's the only thing i see that could cause problems.
Of course,if the airport card can be swaped that could solve any antennas imcompability.
Some time ago i replaced the top case with mate screen from a 2010 macbook pro with a top case glossy from a macbook pro 2011.That time i had to swap the airport card because the 2010 had 2 antennas and the 2011 had 3.
Any help?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I'm having the same question. Did you change it? Is it working?
por
I would like to know too please.
por
isight cable is different. will not work
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
3 Respuestas
Solución Elegida
Nope, They are different.
Fue útil esta respuesta?
Calificación 1
Plug it in and see what happens
Calificación 0
The other answers are careless and poorly worded. Yes, you absolutely can swap the screens. It's just the iSight cable that will not be compatible, the screen itself and wifi will work perfectly fine.
Calificación 0
Añadir tu respuesta
faocisco estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 306
