Repair guides and support for your Samsung TV.
Preguntas 1124 Ver todo
46" Samsung Television won't power on
I have a Samsung LN46A530P1FXZC television and for some reason it won't turn on. After moving (wasn't dropped) when plugging the power cord in, I can't seem to get any power to the set and it won't turn on. Is it shot? or is there a fix.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Lovjoy, of course you made sure it was properly plugged in and the plug has power. If so, you should (unplugged of course) open the TV up and check the power fuse. Use a multimeter to make sure that you having power to the PSU. Download the service manuals from here and see if you are up to working on it.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Correct But this set has 3 fuses so make sure you check all three on the power board.
por
Join the class action law suit or if your blood pressure is low, try calling calling them ;-) They will give you the run around of your life. At the end they gave me two numbers to call. I checked and they were both to THE same damned people i was talking to.
https://topclassactions.com/lawsuit-sett...
Calificación 2
Añadir tu respuesta
Lovjoy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 3,102
