Data cable replacement 2133 / 2266 same?
Can the hard drive data cable for the iMac intel 20" 2266 be used in the iMac 2133? Is installation on the 2133 the same as the 2266?
Es esta una buena pregunta?
Not sure why the question here, did you damage the SATA cable? Or is the drive bad?
Both systems are SATA II (3.0 Gb/s) and the systems are laid out the same. Both support 3.5" drives and both use an external temperature sensor which is stuck on the external part of the drive.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 61
