Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2994 Ver todo
Can I connect a power supply direct to my iPhone?
Hi,
Something happened to my iPhone and it now only charges when off. This is a pain, I hve tried resetting it and using other leads to no joy.
I am in a situation where I have no money at all to buy anything. I only use my phone at home as I don't leave the house .
Could I connect usb wires directly to the terminals the battery connects to on the iphone? As in dissemble the phone and do this?
The only power source I have is the USB from a slimline ps2
Would this work?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
I think I can do it , I just don't want to short the phone out or blow it up!
por
You can but you need to protect the battery from over charging.
por
Can I not just remove the battery? I am not interested in having the battery?
por
Will the power from a ps2 USB be ok to do this?
por
Yes it would supply 5 Volts DC
por
Mostrar 21 comentarios más
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Respuesta Más Útil
It will work as long as you don't have (or later get) a problem with your battery or cable. If you do you risk damaging the USB port from whatever you're using.
The charging issue is likely either a bad charging IC or one of the components around the battery connector is damaged. Have you or anyone else been disconnecting the battery lately? If so, if you have a magnifying glass you'll probably find that one of the small resistors or caps by the battery connector terminal is missing. It's VERY easy to do. Replacing it should fix the problem.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Hi vs, no, haven't been disconnecting the battery at all. So no idea what has actually happened. All I know is I don't leave the house so I don't need the battery and would like to come up with a fix where I can just connect my iphone directly to my power source
por
Just to confirm, the current set up charges when off
por
I would just specifics of where I can connect my wires too from my power source
por
Vs, you give good answers. Please expand your profile ;-)
por
Power gets applied between the 2 outside pins of the battery port. There's an image that was posted elsewhere on ifixit that shows the orientation on iPhone 4. 4s is similar:
https://d3nevzfk7ii3be.cloudfront.net/ig...
FYI If you're not sure which is which you can use a voltmeter (or multimeter set to read voltage) to check the pins of the battery itself. Even "dead" batteries will seldom read 0V.
por
Mostrar 2 comentarios más
Añadir tu respuesta
john jones estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 1,040
