Why won't my phone stay one off of the changer?
When I take my phone of the charger it turns off immidently. Some time if I press on the screen a lot it will stay on. Also I can't turn my wifi on. Can you help?
Es esta una buena pregunta?
I am guessing your problem is related to the battery. Only turning on when connected to a charger can be a sign of a dead battery. But If pressing on the screen can keep the phone on for awhile when it's disconnected from the charger, then the battery's connection to the logic board may be loose. Try reseating the battery's connection to the logic board to see if this will fix the problem. If not then a new battery should solve the problem. You may also check for other loose connections to see if that could be causing your Wi-Fi problem. Hope this helps.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 81
