Pls HELP! Anybody know what this code is? 4SNS/1/40000000: lbor-9.426
I run extended AHT on my MBP 2011 13" and this came up on the results.
Please I need to know what wrong with my MBP.
It runs very slow and stuttering.
Thank you in advance.
Es esta una buena pregunta?
4 comentarios
denzdaniel, that looks like a Battery Current Sense error. Have you tried a SMC reset?
- de oldturkey03
yes i did, 5 times! I even did the NVRAM reset. Still slow macbook pro.
How positive you are that the battery sensor is the problem?
thanks.
- de denzdaniel
Hi Mayer,
DV13 are the last serial figures.
Running Mavericks 10.9
No anti-virus installed, no MacKeeper.
The problem is caused by the coffee spill.
I did the rice thing for a week, cleaned the Logic Board with isopropyl.
I cleaned all surface carefully and all port. I used the blow dryer to dry it.
It works, but it is just super duper slow. Yeah i get beachballs, but the system is just slow. Everything is slow.
Boot up takes forever, after login everything just is just very slow.
So i did the AHT then I got those numbers/codes.
I will try to boot to an external drive thanks. I will update you.
- de denzdaniel
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*
- de mayer
