Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Recovering data stored on NAND chip on iPhone 6
Hi,
In order to recover data stored on the NAND chip of an iPhone 6 motherboard is it enough to desolder the NAND chip and solder it onto a donor board. I am wondering if some additional chip like the CPU, might also need to be swapped. Does anyone have any experience doing this? Any opinions for what to watch out for would be appreciated. We are very skilled at the physical desolder / solder process.
Thanks,
Curt
Es esta una buena pregunta?
Puntuación 6
6 comentarios
Did you ever resolve your problem? I am in similar situation, recently had a baby and lost 30 days worth of photos (hadnt synced in a month, no cloud set up) and smashed my phone in the Jeep. Appears chip is fine but board is cracked. I'd really like to recover these photos/videos of the baby.
- de
Were you able to recover your photos? I have two small babies and in trying to sync my photos today my phone backed up to 2014 so I've lost 2 years of memories. Any help would be appreciated!
- de
I any case it is not only the flash nano that need to be put on a donor board but also the processor as the memory and are paired series no etc
- de
https://www.youtube.com/watch?v=58-7cg9c...
I just found this video on youtube, it shows it is able to transfer the Memory chips to new motherboard and retrieve data back. But I don't have that skill to do it. Hope this can help somebody who are able to do that. The stencil for soldering you may found on china online shop.
- de
Hello did you have any luck with this??
- de
Mostrar 1 comentario más
Agregar un comentario
9 Respuestas
Solución Elegida
Not possible unless you take the A8 CPU to the new board as well.
The date inside the NAND is encrypted with AES256 by the A8, each A8 has a unique key for that. If you take off the NAND chip and put it in a programmer, you can dump the whole image easily but you'll need Tony Stark to help you decrypt it.
Fue útil esta respuesta?
Puntuación 11
1 comentario:
can you please name any program or programmer to dump whole NAND ?
- de
With every new phone, the parts of an iphone that are "married" with one another have increased.
What i can say is,that it is at least linked to the CPU and the Basebandchip. I'm almost sure that this list is not complete.
But this only is imporant if you want to transfer those chips on a another logig board. The activation will fail if one of thos parts are missing. But no idea if some kind of machine JTAG or whatever exists, that can read those parts without the phone.
Puntuación 3
3 comentarios:
That is exactly what I want to do. I think this board is beyond recovery and I want to recover the data which it contains. I'm prepared to purchase a brand new iPhone 6 just to get a good working donor board to migrate the chips onto. I know a professional business which specializes in this type of rework but I need to tell them exactly what chips to move over. Sounds like I have to get them to move the CPU and baseband chips along with the NAND chip. Correct? Do you think there might be some other way to look at this problem?
- de
For example: The iphone 5: CPU and NAND chip carrry part of the serialnumber, one can not live without the other. Further the baseband is bound to the serialnumber: meaning serial A can only properly work with IMEI B, which is stored in the Basebandchip.
So far we have CPU(U1), NAND(U4) ; Baseband (U501_RF).
And here is where my knowledge ends. I have no idea what apple did on the iphone 6. But I doubt it have become less components that are depending on each other.
It must be very important data when you go through all this expensive and risky challenge. Since one missing fragile pad after desoldering a chip can make the differnce between a working phone or not.
The epoxy apple uses to glue the ics doesnt make it easier.
Is there another way ? Not to my knowledge .Those IC's have hidded partitions that have no read and no writing privileges making it impossible to clone the data. As for reading it ? I have never seen something that can do that. But that doesn't mean much.Goodluck
- de
Sadly, this is really not practical. You'll end up just killing your replacement phone. The art of desoldering these chips without damaging them (or the board and other components) is just beyond what you can do on your workbench.
- de
If the iPhone is dead, people specialized in data recovery from iPhones can try to "wake up" the iPhone just enough to pull a back-up (Android phones such as Samsung or Nexus or Sony, etc. require a different approach). We do this often and many times were able to get pictures and contacts from iPhones thought to be dead. Sometimes the phones were sent back in working order.
But if the data has been erased and/or replaced by new or older data, you cannot get it back.
As for the original question, it is not possible to just pull the NAND from the iPhone and read it. It has to be paired with other components (depending on the iPhone model, those components vary). If you are skilled enough, you may then transfer all the critical components together to a working board. But that's not guaranteed to succeed since the components may be damaged before or during the transfer process. And the level of skill required to succeed is very hard to attain.
Puntuación 2
Hello Curt Ingram,
Personally i like what you are trying to do but its like breaking the most secure prison in the world :-). ElBo's comment is right. you wont tag them as a system. 64bit architecture is more complicated than 32bit. But there is no any impossible things to do & someday you can do it. never give up
Puntuación 1
http://9to5mac.com/2016/02/03/iphone-fla...
if they can transfer the data from a 16gb memory to 128gb, it is possible to do what you want to retain your photos . Good luck on finding help in this . It can be done though.
Puntuación 0
5 comentarios:
No they cannot transfer data from the chip.
- de
Thank you Tom Chai. How are they able to upgrade the memory from 16gb to 128gb? It looks like that they transfer the image over to the new chip. I was thinking that Mr. Ingram could find someone to get the same results. Have a great weekend!
- de
They just do a backup on their PC for you, that's it.
- de
They just copy serial number onto new chip, then restore iphone backup
- de
It's been a little over a year, any luck figuring out the answer?
I have an iphone 6s, lost everything when connecting it to my computer and it synced to itunes -- my new born baby's pictures and videos are what I am worried about.
A previous version of iOS (from a few months ago) is on my phone now, and online data recovery software programs are no help.
Any suggestions?
Puntuación 0
1 comentario:
You seem to have restored an older back-up onto your iPhone. You erased the current data and replaced with older data.
If this is indeed what happened, you cannot recover what has been erased. Sorry..
- de
Can bedone.
Option 01 https://youtu.be/2jRzm_RFWXE
But never did tried it personally.
Puntuación 0
just possible to Recovering data by icloud or before iphone
The NAND flash memory in each iPhone is uniquely encrypted by its CPU using AES256. Encryption keys are generated from secure keys hidden inside the CPU, random numbers generated on each iOS copy and user passcode.
Puntuación 0
Who does this type of data recovery? I have several clients waiting. Please call the number listed in my profile
Puntuación 0
1 comentario:
I am also want to recover data from encrypted. My new born baby videos stuck in my phone I sent my phone to Drivesaver they said storage full and logical corruption. Is any possible to recover two months photos and videos?
Please need help…
- de
Añadir tu respuesta
Curt Ingram estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 20
Ultimos 30 días: 83
Todo El Tiempo: 33,317
